Another deck thread... but different because it's ground level between 4 walls with hot tub
9 Apr 2016
I'm sure this has been posted but after searching through all the archives i'm still a little unsure.
I'm building a ground level deck 3x6m in a yard surrounded by 4 brick walls, the ground is currently just mud and clay soil under that. I'm just a little unsure of the footings, mainly because of the walls and the weight of the hot tub that will be going on it.
The two options i'm considering are:
Just rest it on the ground but I figured this would be difficult to level and rot a lot quicker.
Or joists spanning the 3m length, have ledger board on each side with a central support for all joists consisting of a wooden post resting on either a poured concrete footing, or breeze block.
I'd really appreciate your opinions on either option.
There are plastic screw type jacks. Could you place paving slabs then jacks to support the rails?
Adjust to get the fall
Any moisture should be below the wood
