I was outside today measuring for new windows (thread posted in the windows section) when my neighbour bumped in to me and asked what I was up to.
We had a chat about her new windows and she mentioned that when she had them fitted she had the original wooden frames removed which is what I want done as well. Most of the other houses on the road have had double glazed units fitted inside the existing frames.
Apparently this is because the wooden frames are supporting the exterior skin of the walls so it is more expensive (and disruptive) to remove them and put lintels in.
Whilst googling for lintels I came across a product called Helifix which sounds like an ideal solution and more in my skill range than dismantling a wall. Has anyone used this and does it work as described?
If this isn't the right product for the job what should I be using? I have seen people mention angle iron for solid walls but not sure how this sits between the inner and outer skin with the header bricks?
