flush mounting lighting fitting for bathroom......i`ve got to remove the ceiling rose.Now do i put the 3 reds in a choc block,1 black(nearest the reds) in a choc block,the black(connecteing the brown from pendant) into LIVE in new fitting,and 1 black(connecting the blue from pendant) into NEUTRAL on new fitting.........the fittings given are screws,plugs,and 3 sleeving strips for heat.Also are the choc blocks ok to be in the new fitting or do they need to be outside the fitting?
cheers
cheers
