I want to run a spur from a socket on the ring. The existing socket is flush in the wall. The new spur is ok to be surface mounted with surface wiring clipped to the wall. My question is can you get a flush mount socket which enables you to run a surface mounted wire to the spur without cutting a small channel to get to the back of the flush socket. I know you can get switches with a flex outlet but can you get a soket with a cable outlet.
