Thems the ones I meantCan't you just use a normal floor socket, with the hinged flap?
Is it a vented block and beam suspended floor?, be careful about creating draft ducts. Even the smallest hole while create a tornado of cold air in the winter.
Think you can still get tasteful brass flush mounted floor sockets
https://www.tlc-direct.co.uk/Main_I...oor_Sockets_All/index.html#FP_Floor_Sockets_1Can't you just use a normal floor socket, with the hinged flap?
Think you can still get tasteful brass flush mounted floor sockets. Otherwise make yourself a plywood box for under the floor & put the socket in that- when you cut the floorboard, do it with 2 angled cuts so the cutout bit will just sit on the existing boards.
Well how much are they then? Good God man, spend some of it...
