Any recommendations for LED fitting and dimmer
29 Apr 2012
London
Hi, looking for about 12 led down lighters and dimmer switches for our lounge and dining rooms. Any recommendations?
I am looking at 6 off 60mm and 6 off 85mm.
Electrician has confirmed i don't need fire rated ones as it's a semi detached house rather than a flat. But if not too expensive I can get those as they seem to be of better construction.
Thanks.
Why do you want different sized ones? Won’t that look odd? Or is that what the existing holes are? Can you not make them all ~85 if that’s the case?
hi,yes it is what existing holes are. i was thinking about getting them all at 85 mm and now you have confirmed what i was thinking..
any recommendations on supplier?
At 85mm the only fitting that immediately springs to mind is the Aurora M10 but unfortunately the adjustable version. Most standard LED downlights are around the 70mm mark.
This is another option, we fit Enlite all the time (not those, the E8’s) and they’re fantastic. That ones is even brighter so good job you’ll be dimming them.
As for a dimmer module, BELL Lighting make a good one, basically just works out of the box, I’m sure others have preferences
