LEDs and dimmers, Stepped dimmers?
11 Jan 2010
Kent
Hello,
We've got LED downlights in the kitchen (spec below). I'd like to change the light switch to a dimmer.
1. Anyone got a suggestion of good dimmer switches for these lights?
We've used Varilight JQP252W V-Pro dimmers for other rooms but the dimmers are a bit variable (different LEDs at different brightnesses, bit flickery). Any better suggestions?
2. Is it possible to buy a dimmer that has 2 or 3 set points, say high, medium, and low, rather than twisty knob type dimmer?
Integral LED ILDLFR92C017 Satin Nickel Tiltable Fire Rated Dimmable Downlight IP65 55deg 3000K 11W
  • LED wattage: 11W - Equivalent to 62W
  • Colour temperature: Warm White (3000°K)
  • Emits up to 850 lumens
  • Dimmable
  • Colour rendering index: >=80
  • IP65 rated
  • Cut out diameter: 92mm
  • Average lifespan: 35,000 hours
  • Diameter: 100mm - Depth: 64mm
  • 3 Year Warranty
Think carefully why you want dimmers in a kitchen. It is a work room where you want maximum light.
Thanks. We've got lots of light in the room, but its a kitchen diner so would be nice to have the bright downlights dimmable.
