I know I'm probably on for a flaming; but here goes
Anyone have experience of sourcing the best possible 15mm white laminated chipboard \ conti-board possible from the usual suppliers?
Stuff I've sourced from Jewson and B&Q is.... well, basically only worthy of chucking on a bonfire! Am cutting with a router and straight 12.7mm bit. 1st two cuts on a new bit are perfect; after that the particles blunt the bit in no time at all and the laminate simply chips like f***! (ok, maybe not that bad, but this should be the best way of cutting conti ever!). Even if I make an initial pass to just pierce the laminate, then 2-3 other deeper cuts it chips!
Peeled a bit of laminate off, they're micron thin and as brittle as egg shell!!! Old kitchen units I've recovered from years ago and kept for templates\testing are far superior with thicker laminate that's more pliable. This current stuffs a joke.
Not tried Focus, Wickes, or other yet - but assume all's the same. Anyone know better. I'm in the Reading, Berks area.
Cheers,
Neil
Cheers,
Neil
