Anyone used tile adhesive from Mapei
13 May 2005
I was advised to use "BAL ctf3" for a tiling job but the only supplier in my area want,s a kings ransom for it. I was told about this product and spoke to there tech department today. Its tile adhesive called "Keraflex Maxi" and its made by "Mapei". Has anyone used it. I told there tech they were large format tiles going on an old skim of plaster and some would be going direct onto unskimmed water resistant plasterboard, he advised using another of there products called "Primer G". So once again has anyone used it. I was advised to use "BAL APD" for this job originally. I not well up on tiling adhesives so i dont know if these products are any good.
Mapei have a good reputation and are as reputable as BAL or Ardex, however my personal knowledge of them ends there.
My business is marble and limestone and I've found on the odd ocassiona I get staining in the stone from Mapei grout so I tend not to use it.
For normal tiling I'd be happy to use it, and use their primer, it's best to stick to one manufacturers system.
Thanks Mudster, Mapei may be the way to go. Seeing as how Topps are holding the Ball stuff to ransom :lol: . I got quoted £17.99 for 20kg of keraflex yesterday and for Primer-G £3.48 for 1kg and £13.99 for 5kg . Its liquid so it seems strange they sell it by the kg. I dont know what its coverage is though they didnt have that info to hand.
Primer generally goes a long way unless you have appallingly dry walls.
Mix it to spec and get yourself a paint tray and roller and off you go, it goes everywhere though, so plenty of sheeting if you have anew bath already fitted.
