Hi all,
Got a few questions and looking for a little input if poss.
Recently had to rip out old plasterboard, tiles etc in a bathroom as it was time for a refurb.
Basically there is a bath which has a shower above. It is to be tiled around the bath/shower but the tiles do not go all the way to the ceiling, the stop 18-20 inches (approx) before the ceiling, this section is to be skimmed and painted.
I intend to use aquapanels where the tiles are going and moisture resistant plasterboard above which will be skimmed.
How would you suggest sealing the joint where the aquapanel meats the MR plasterboard, - adhesive, grout, silicone? As mentioned there will be plasterboard above the aqua panels and also to the right of the bath where the shower screen ends so I want to get this joint water tight.
What's the best way to seal the joints where the aquapanels meet each other around the bath-use the available aquapanel tape or just fill with adhesive and then scrim tape?
Do the aquapanels require priming with something like Bal or not? I suspect the panels dont tbh.
Oh and is it necessary to use the ceramic screws for the aquapanels?
Thanks folks.
Thanks folks.
