- Joined
- 21 Sep 2011
- Messages
- 4,844
- Reaction score
- 1,172
- Country
Hi All, I have some of the old tiles fixed with cement and then tiled over with later ones to remove.
I will end up with bare brick at the end, I want to use a backer board (insulated if possible) fixed direct to the brick (uninsulated cavity wall) the makers of Aquapanel say fix to battens but that will be too deep. I have however fixed Aquapanel direct to the wall with adhesive / plaster and then secured with screws on small areas before and it worked fine.
I really want to end up with the panel flush with the existing plaster above the tiled area, can anyone suggest another product that might be better please?
I did wonder about this, http://www.pureadhesion.co.uk/marmox-1250x600x10mm-insulated-tile-backer-boards.html
