    Dismiss Notice
Araldite, best modern equivalent
Discussion in 'Tools and Materials' started by donrkebab, 17 Apr 2019.
  1. donrkebab
    donrkebab
    15 Apr 2012
    507
    Thanks Received:
    25
    London
    Country:
    As the title says, I want to fix a plastic spigot into the end of a steel pipe to achieve a waterproof joint. TIA
  2. foxhole
    foxhole
    14 Mar 2006
    13,576
    Thanks Received:
    1,440
    Kent
    Country:
    What’s wrong with araldite?
  3. Burnerman
    Burnerman
    7 Feb 2008
    19,235
    Thanks Received:
    3,718
    Northumberland
    Country:
    Araldite is one of the best epoxy adhesives there is....most others are a clone of it in some way.
    However, its not really suitable for bonding plastic to metal......especially if the plastic is soft and there is pressure involved. You may get away with it.
    For a genuine purpose made adhesive, consider Loctite Abelstik 45.
    John :)
    • Thanks Thanks x 1
  4. Have a look at Loctite Epoxies.
    • Thanks Thanks x 1
  5. mattylad
    mattylad
    27 Apr 2008
    5,917
    Thanks Received:
    317
    Country:
    I use Penloc at work, dries in about 5 minutes, sets hard in 24 hrs.
    Sticks stainless steel together well, the only way to get it apart then is to use a gas burner and heat it up very very hot and pull hard.
    Sticks like poop on a blanket.
    • Thanks Thanks x 1
  6. ^woody^
    ^woody^
    3 Sep 2006
    25,497
    Thanks Received:
    3,125
    West Mids
    Country:
    Would a UV cure adhesive be useful for this? These are normally used to bond metal and plastic to glass to form a high strength and water resistant joint, that dries clear.
    • Thanks Thanks x 1
  7. donrkebab
    donrkebab
    15 Apr 2012
    507
    Thanks Received:
    25
    London
    Country:
    Thanks woody, have you got a name
  8. ^woody^
    ^woody^
    3 Sep 2006
    25,497
    Thanks Received:
    3,125
    West Mids
    Country:
    Bondic, or I think I've seen something similar from JML on one of their advert stands in one of the sheds
    • Thanks Thanks x 1
  9. Not sure what the spigot or pipe are for but could it not be threaded and use proper plastic pipe fittings?
  10. donrkebab
    donrkebab
    15 Apr 2012
    507
    Thanks Received:
    25
    London
    Country:
    Unfortunately no, the pipe is very thin wall and a non standard size/diameter.
Loading...
Share This Page
