Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Thank you --yes that is the whole reason for my post as they are all 12v, there are proper 240v 300degree temp ones available that I have since found out from the helpful posts on here.
Those that you see marked as 12v are only so because they are playing safe.
The connector still works at 240v, its just that its not safe if it has no insulation over it, which it cannot have when on the end of an element.
Yes, a decent nichrome/high temp one would be better - but if you cannot get one then you have to go with what you can get.
