are there any water heaters with expansion tanks inside
11 Oct 2016
Hi, Im looking for an 80L electric water heater , apparently some have an expansion tank internally ?
is that correct ?
If so does anyone know of any ?
thanks in anticipation
Thanks, I need a wall fitting one for a small flat.Thats cheap
Perhaps will have to fit an expansion vessel after all
Be aware that fitting such an appliance is not a DIY job - it must be done by a G3 Registered installer and is notifiable to Building Control
As @muggles correctly says you can not install these without a G3 qualification.
McDonald Cubeflow have the wall mounted rectangular heaters with built in header tank
https://www.mcdonaldwaterstorage.com/products/rectangular-hot-water-tanks#CubeflowMini
You can however install these McDonald Cubeflow as DIY, they dont have or require an expansion vessel.
