- Joined
- 22 Jan 2006
- Messages
- 67
- Reaction score
- 0
- Country
We had a problem with our 8 year old Genus 27 MFFi some time back and, cut a long story short, got someone to tell us the bad news that we needed a new pressue vessel (it had other minor problems mainly with the wiring which were fixed). However the fitter has since ceased trading and the two others we have approached are a tad too keen to supply a new boiler as the only option. At the moment the pressure drops to zero after the system is not used (during the night and parts of the day). It takes around four or five hours to drop from around 1.5-2.0 back to nothing. We have to top it up twice a day normally using the little blue turn screws under the unit and then we start it up.
The rads have all been checked and there are no leaks anywehere. The last engineer put a small 'plug' device on the overflow pipe outside to prevent any possible leak from there but it hasn't altered anything.
A few question:
1. Will a new pressure vessel mean the problem will definitely be fixed (or is it more of a pot luck thing)?
2. How much should a pressue vessel and labout cost for a Genus 27 MFFi or does fitting a new boiler make more sense?
3. Is topping up the system as we are doing now dangerous?
Many thanks
A few question:
Many thanks
