Hi everyone,
I’d really appreciate some advice, as I’m currently helping a friend install artificial grass in his garden for the kids to play on.
Here’s the plan for the base:
Questions:
Any advice or suggestions would be greatly appreciated!
- Type 1 MOT (hardcore)
- Compacted
- Sharp sand
- Flushed with straight edge or timber
- Weed membrane
- Artificial grass
- Timber edging around the perimeter
Questions:
- Can I fill the required depth with MOT Type 1, leaving the final 30mm for sharp sand so that it's flush with the top of the timber edging?
- Half of the area where the grass is going is currently concrete.
Should I:- Put MOT Type 1 on top of the concrete and compact it to raise the level?
- Lay sharp sand directly on the concrete? (Though this would result in more than 30mm of sand.)
- Or break up the concrete and bury it to help raise the ground level before building the sub-base?
- Would it be a good idea to remove the concrete where the timber edging is going to ensure the edging is securely fixed and sits properly?
- If the total ground depth is 150mm, should I buy 200mm-deep timber and sink it into the ground for extra stability, or is 150mm timber sufficient as long as it sits flush with the finished surface?
