- Joined
- 24 Jul 2023
- Messages
- 9
- Reaction score
- 0
- Country
Hello everyone. I have started the preparation to lay a concrete slab in my front garden for a steel Asgard bicycle shed. I've never done anything like this before, but have researched extensively on here (thank you) and YouTube etc. Does my plan look ok? Many thanks in advance.
Objective:
Lay 2400 x 1250 x 100mm concrete slab in front garden, Back of slab will (ideally) be laid adjacent to garden wall pillar, leaving a ~10cm gap behind the slab to the garden wall (illustrated in photos). Slab will sit proud of block paving by 20mm.
Plan:
Remove shrub roots
Continue to excavate to 190mm depth
Build shuttering
Rent whacker, cement mixer and concrete float
Lay 100mm MOT Type 1 and whack down
Lay 10mm Blinding Sand and whack down
Fit DPM
Cut & fit rebar and spacers
Mix, pour and level 100mm C25 concrete
Wait 1 hour and float concrete
Wait 24-48 hours and remove shuttering
Make good block paving
Questions:
Is it sensible to build the slab right up to the garden wall pillar? If it is, do I just expose the footings and try and pour around them (obviously will make shuttering a bit more difficult). If it’s not, I will just bring the whole thing forward another 100mm to leave a gap between the pillar and the slab.
Is it ok to leave a 100mm (or more) gap between the slab and the rest of the garden wall? If so, do I fill it with shingle or something similar?
Is it a good idea to have the slab sitting 20mm proud of the block paving and rest of garden?
Objective:
Plan:
Remove shrub roots
Build shuttering
Fit DPM
Questions:
