At risk of splitting or normal???
15 Apr 2009
Manchester
Hi All,
May be a numb question but I just want to be sure...
I’ve just had some timber delivered from a merchant and one of the pressure treated 6x2s has cracking that runs along length but also through the centreline.
I know cracking is common as wood dries out but is this the same or is it liable to split over time because it passes through the centre if I use it?
It is for the seat bearers and legs on a picnic bench and will be bolted using carriage bolts so I don’t want it to open up along its length and fail anytime soon.
I’ve never thought much about it before as usually selected wood myself so just avoided cracked pieces.
Mike
Some images for info:
12 Jul 2004
Surrey
its with the grain so won't effect strength to any great extent
but from a practical point off view a vertical use will stop water and dirt collecting in the crack
11 Jan 2012
London
Yes, it is prone to split.
In fact, if you cut a foot off the length, you could probably split it with your hands.
