atag q 38s system boiler
3 Jan 2006
Nottinghamshire
Hi , can i use honeywell cmt 927 wireless stats with atag q series system boiler , the property has two zones for heating & one for HW . atag say they must be volt free to boiler connection , will these be ok or do i need differant stats .
Your honeywell will be fine.
As long as its wired correctly!
atag tech bloke said they needed to be wired type. as volt free connection required . could your give me a bit more detail about how to wire these up ( wireless type ). system has 2 zones for heating so i have got two stats one upstairs one down . i need the info as i will check my electrian has wired everything ok . cheers
It isn't a problem being wireless. There are two boxes. One is wired to the boiler and the other sits inside and sends radio messages :) The instructions will indicate how it should be wired for volt free connections.
Run the stats to the MVs in 240V. Then use the microswitch connections on your MVs(grey and orange) as your volt free switching.
