Hi Guys,
As part of the rewiring project, I will be also be installing CAT6 and AV cabling throughout the house. I have already aquired a floorstanding 40-ish-U comms cabinet, which will be used to hold all the bits I require.
I already know what I am doing with the networking, but am unsure of what product and cables etc are the best to use for the distribution of the others and if the signal quility will be reduced.
1. Sky Dish.
I want to be able to wire a single cable from the dish to the cabinet and distribute from there. Is this feasiable as I know that if you have multiroom, Sky installs the multiple cables direct from the sky dish? Are there any devices that you can use to distribute this easily?
2. Aerial Cable
I want to be able to do the same here also.
3. Has anyone played with/installed CAT6 distribution devices of SCART, HDMI, Aerial, Sky, such as:
http://www.onevideo.co.uk/hdmi-cat5-extreme-p-525.html
Do they provide a proper lossless signal?
Is it better to stick with high quility Aerial/Sky cable instead?
4. I have been told that as CAT6 cable is high quility, it can be used as a cheap alternative to the more expensive proper speaker cable. If you keep all the solid strands as + and stripped as - you will get better noise reduction. Does anyone have experience of this?
I don't think I want to goto this trouble for the interconnects though:
http://forums.audioholics.com/forum...1ef13a16893d01&attachmentid=2285&d=1133493740
Any comments or help greatfully received!
Ad.
1. Sky Dish.
2. Aerial Cable
Ad.
