Auto airvent leaking
17 Oct 2006
My heating system has a Flamco Flexvent automatic air vent in the primary circuit to the HW cylinder, immediately after the mid-pos valve.
The valve has started to leak from just below the red button on the top - large damp patch on the airing cupboard floor.
I suspect that dirt has got in and is stopping the valve closing. The vlave seems to be in two parts and, according to the Flamco website you can remove the top half for cleaning.
Has anyone ever done this? If not how else do I solve the leak problem?
Flamco also say that there are two washers below the red button which should swell up to prevent water leaking!
I would not strip it down as it dont work, believe me I have tried
either replace it or twist the red cap shut and forget about it :)
They look posh and cost more, but don't seem to be any more reliable than the 99p variety. Nothing special, if you look at the design.
If you are worried about the replacement leaking, or it is inaccessible, it might be worth splashing out and fitting a SpiroTop air vent. They are about £60 but very reliable.
