The cleaner is a good analogy. If the substance in the spill were a hazardous acid you'd expect to get someone who knew how to sort it out. The hazard in re-setting this MCB is not in resetting it, rather in the proximity to live parts and the lack of protection from contact with those parts.
Lets say the MCB has re-set due to a dead short witin the cabinet you mention. If you just re-set it without taking precautions or just knowing what to look out for, then the copper cable or MCB can explode throwing molten metal out, with whatever injuries resulting. Now this can happen to anyone but someone trained and entering a live cabinet will wear te proper PPE and know what looks out of place or what could be hazardous. I know it seems unlikely, but it needs to be considered or assessed.
Possibly what you need to do is mention this kind of situation to your employer and ask them to get the spark in to give you and some others a run-through in terms of proceedure etc, and maybe buy some Gloves overalls and a mask if you're likely to have to re-set in a live board in future.
An example of how an accident could happen would be when you are reaching in to the board to switch on the breaker, and someone (probably that moaning minnie you mentioned) comes in and drops something or speaks loudly to you. You turn to see and your arm & hand wanders onto a live part as you move. You could loose some fingers that way. I know of a guy in GE in the US did just that.
