    Dismiss Notice
Automatic Bathroom Light?
Discussion in 'Electrics UK' started by RP66, 15 May 2019.
  1. RP66
    RP66
    16 Jan 2007
    140
    Thanks Received:
    Devon
    Country:
    Our bathroom has no windows therefore the light needs switching on each time you pay a visit, during the night the pull switch makes a real noise, and wakes my other half up.
    Is it possible to fit something in the existing light switch box that senses someone's presence and will switch light on when entering and off when leaving.
    The possible switch needs to operate the extraction fan as well.
    Any suggestions please.
    Thanks.
  2. Sponsored Links
  3. RP66
    RP66
    16 Jan 2007
    140
    Thanks Received:
    Devon
    Country:
    Sorry slight mistake it needs to fit in place of the existing pull switch and use the existing wiring!
  4. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    3,944
    Thanks Received:
    786
    Durham
    Country:
    Plenty of options. Google 'PIR light switch', your main problem will be if there's no neutral at the pullswitch, other issue may be poor detection if the pullswitch is in a corner.
  5. aptsys
    aptsys
    16 Sep 2007
    1,806
    Thanks Received:
    141
    Cambridgeshire
    Country:
    In which case a microwave-based detector will work more effectively.
  6. JohnW2
    JohnW2
    28 Jan 2011
    46,402
    Thanks Received:
    2,999
    Buckinghamshire
    Country:
    In addition to what has already been said ... a common question we get here relates to the fact that family members get woken up/disturbed by the noise of a bathroom extractor fan if the room is used during the night. I therefore wonder whether resolving the issue of the noisy pull switch would, alone, necessarily be enough to resolve your problem?
    It would be possible to arrange things that the (or a) light (but not the fan) came on at night when someone entered toi room, but that would be appreciably more complicated.
    Have you considered forgetting about the existing light/wiring and simply getting a cheap battery-operated PIR LED light? I use several in my house - they are readily available, often for under £5 (see example here) , requiring no wiring or installation, the batteries last for many months with the sort of usage you're talking about, and the amount of light should be adequate for most nocturnal trips to a bathroom (and you could always use more than one if you wanted). ... and, of course, it would avoid the fan noise as well as the sound of the pull switch.
    Kind Regards, John
    • Like Like x 1
  7. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,783
    Thanks Received:
    2,858
    London
    Country:
    How big is the bathroom?
    Do you need to use a pull-switch, or could you have a normal wall one?
  8. nitro23456
    nitro23456
    29 Nov 2008
    196
    Thanks Received:
    3
    Country:
    You can get lightbulbs with PIRs built in. Just search on amazon.
    Iv got one on the landing so the kids dont fall down the stairs when they are looking for the toilet in the night.
  9. JohnD
    JohnD
    15 Nov 2005
    69,866
    Thanks Received:
    3,937
    Crossgates
    Country:
    Cook Islands
    consider the cost of running an ordinary, low-wattage LED lamp.
    you will find it is cheaper and less trouble to leave one running continuously that to buy a timer or photocell.
    Though I still use timers for my stairs and porch, it is not worth buying replacements when they fail.
  10. Sponsored Links
  11. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,783
    Thanks Received:
    2,858
    London
    Country:
  12. JohnW2
    JohnW2
    28 Jan 2011
    46,402
    Thanks Received:
    2,999
    Buckinghamshire
    Country:
    Probably not 'cheaper' (in the long term), if the timer/photocell/PIR is cheap and lasts for at least a few years, but certainly a pretty trivial cost (~£7/year for a 5W LED).
    However, as for 'less trouble' if, as in the OP's case, there is a light-switch-controlled fan, then a certain amount of re-wiring would be necessary to address that issue.
    As I wrote in post #5 above, I personally address such requirements with very cheap battery-powered PIR LED lights.
    Kind Regards, John
  13. JohnW2
    JohnW2
    28 Jan 2011
    46,402
    Thanks Received:
    2,999
    Buckinghamshire
    Country:
    One can and, indeed, I use some in my house. However, use of them requires that the lightbulb is permanently powered which, in the OP's case, would mean that the extractor fan would be on continuously - so some (wiring) work would have to be done to get around that problem.
    Kind Regards, John
  14. RP66
    RP66
    16 Jan 2007
    140
    Thanks Received:
    Devon
    Country:
    The fan has a switch outside of the bath room to isolate it, therefore there would be no need to change any wiring, may well try the LED bulb option and just leave the switch in the 'ON' position.
  15. JohnW2
    JohnW2
    28 Jan 2011
    46,402
    Thanks Received:
    2,999
    Buckinghamshire
    Country:
    Yes, you could use that isolator switch to control the fan, but then you would have to manually turn the fan on and off with that switch, as required, and the fan obviously would then not come on 'with the lights' (or 'run on' for a period after the lights were turned off) - which is the functionality which people usually want of a bathroom fan.
    If you manually turn off (and remember to manually turn off!) the extractor fan as you leave the bathroom, it probably won't achieve very much in relation to either moisture or odours.
    Kind Regards, John
  16. bsr
    bsr
    5 Aug 2008
    479
    Thanks Received:
    35
    Gloucestershire
    Country:
    • Like Like x 1
  17. foxhole
    foxhole
    14 Mar 2006
    17,121
    Thanks Received:
    1,958
    Kent
    Country:
    I replaced an internal pull switch with a sensor , also had timer run on so rarely turned off while occupied ( unless you stand perfectly still in the shower for a while) simple wave of the arm turned it back on.
  18. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
