hi, i have an 12kw aztec electric boiler that keeps going into lockdown, the only way to get it to run is to switch the electricity supply off then on again but we have to do this virtually every time we want heating/hot water. there is a megaflo tank and water was running constantly out of the overflow we've had a couple of different plumbers out to look at it, one replaced some leaking valves either side of the pump the other repaired some wiring in the boiler and changed the TP valve on the megaflo tank. The overflow of water has stopped but the boiler still isnt working properly. When it runs either the boiler or the pump (im not sure which) make a loud whirring noise for a few seconds then it either quietens down and runs or goes into lock down.
obviously we are going to have to get someone back out again but i would like to know what the problem could be as the people we have had seem confused by the fact that it is electric.
many thanks for any advice
Cat
Cat
