Would having a metal tank prevent it?
Indeed it would
Bahco it was the plastic header tank that got that hot that it collapsed so cylinder downstairs would not make any difference.
Numpty Header tank cws both basically same just terminology and made of same plastic . Tell me how to support it to stop it collapsing in this instance..
And how could a open vent safely be vented to outside firstly you are not allowed any valve or obstruction on it so what is going to stop it blocking over time as many over flow pipes do
Open pipe to elements still has a very good chance of blocking so taking away a safety element. Bees wasps and other insects love to make there nests in little holes like this ,even mice and over the years obstuctions become as hard a concrete seen it many times.
It probably had properly made base etc the problem is the amount of heat that got into the tank(header or cws) and because of what it is made of (which meets the standards) the sides just buckle and collapse a bit like those swimming pools you see in funny video programmes
