back boiler and combi boiler
Towards the combi boiler, I know this would be the long way to the radiators but the thought was if the combi was heating the water for the rads as well then it would not use as much gas to heat the water. I am making the assumption that combi boilers monitor the temperature of the water return and adjust the amount of heat required to get the water to the correct temp.
cheers for the help but i feel none the wiser lol. I will speak to my plumber when he gets back from his holiday and see what he says. cheers again mate
do you mean the water could get to hot before entering the combi?
could you put a valve that would bypass the combi if the water is to hot
