Thanks for the reply I will give that a try.
It has a header tank in the loft and as I have very limited plumbing skills, could you recommend one which is VERY easy to use, ie pour it in and walk away, job-done style?
Might be worth checking the rad valves as one of them may be leaking un-noticed and the water running down the pipe either onto the carpet or below the floor.
