Hi Guys
Im looking to dig out my basement for conversion into habitable rooms. I will be doing this myself as a competant DIYer.
I've been in contact with a structural surveyor who has advised me on digging 4 trial pits to inspect the current foundations which I have completed. Current head room is 2100mm and im looking for around 2600mm of headspace. The base of the footings extend 800mm down.
I plan to dig out the entire basement to level with the base of the footings. Then backfill with 100mm of compacted stone and then with 125mm of concrete slab based on his calculations. Then insulate, board and floor above the waterproof membrane depending on what building regs require.
Ill tank the basement with membrane and use a sump & pump system for any groundwater issues (everything dry so far bar damp walls)
I have two questions: Firstly does this sound OK to you? I was a little concerned about my neighbours basement level being higher than mine and if this would put a strain on the wall but the surveyor has assured me that 2 foot difference would be ok.
Secondly, is there any sort of DIY public liability insurance that I can get that will cover me for this sort of work without registering myself as a company? I dont think this will be covered under my standard DIY cover under the house insurance policy.
Any info would be most appreciated.
Cheers
Bruce
Cheers
Bruce
