    Dismiss Notice
Basement Tanking Membrane - Suitable for Ceilings??
Discussion in 'Building' started by Chris Drew, 14 Feb 2021.
  1. Chris Drew
    Chris Drew
    14 Feb 2021
    3
    Thanks Received:
    Country:
    I'm converting a brick outbuilding to a utility room and was planning on using a basement Tanking damp proof membrane to line the walls before Battens and insulated plaster boards go on.
    The roof is flat concrete with rebar running across tieing in to next doors so as expected the ceiling can be prone to damp. It's my first time using basement Tanking Membrane so was wondering if anyone has had experience with it and specifically can it be used on ceilings?
    Cheers
    Chris
  2. ^woody^
    ^woody^
    3 Sep 2006
    34,611
    Thanks Received:
    4,685
    West Mids
    Country:
    Unless the manufacturer says so, no.
    Where is the water that comes through the roof going to go?
    Roof waterproofing should be on the outside.
  3. Sponsored Links
  4. Chris Drew
    Chris Drew
    14 Feb 2021
    3
    Thanks Received:
    Country:
    Makes sense, thanks.
    Its not as if its pouring in or even visibly dripping, its just preparing for the inevitable as I live in NE England and it rains A LOT
  5. freddiemercurystwin
    freddiemercurystwin
    21 Jan 2007
    19,954
    Thanks Received:
    2,223
    Devon
    Country:
    I know I've seen photos on Newlath's website showing their dimpled membranes fitted on curved ceilings but never horizontal but it might be worth giving them a ring, I can't quite see how they'd work in a horizontal plane but they might have a solution. Obviously if that was actually an option you'd have to use a similar system for the walls.
  6. Sponsored Links
  7. Chris Drew
    Chris Drew
    14 Feb 2021
    3
    Thanks Received:
    Country:
    Nice one thanks I'll have a look at that.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
