bath panel
13 Oct 2014
Essex
Problem with bath panel, needs to be 550/560mm high, one I have is only 52mm. Can anyone recommend a bath panel that will fit or suggest how I could add 4mm to existing Wickes 'plastic' panel?
Any help appreciated.
Assuming that's 550mm/560mm!
Run a batten along the floor and screw the bottom edge of the panel to the batten at the required height?
As above then finish off with a white plastic strip to cover the wood.
Thanks guys, edited the size after it was mentioned ! Any ideas where u can buy plastic strip to cover the wood?
Not sure where you are in Essex but I get mine from Direct Cladding supplies in Basildon
http://www.directcladding.com/
You might have to buy three to five metres but they are very cheap and it will cost just a few pounds. They might even have a strip at the correct width to save cutting.
Thank you all for your advice and links. Been a great help and I will follow the advice given.
