bath room priceing
17 Sep 2009
Bradford
hey I have a private job to do fitting a bathroom. The toilets going back in same place and the stack is ok for the new toilet. basin in same place and bath. However all the pipe work needs cutting back and repiping as its in lead. The waste for the bath and basin thats goes in to an outside hopper needs replacing in copper. I also have to change the radiator in the room for a towel rad. The central heating pipes are in copper. I just need to supply the my labour. He is buying the suit and materials. What kind of price would people recommend. I'm in Yorkshire.
£275, (ssshhh if cash in hand) should take 1-1.5 days depending on access to the hopper to change the waste, copper waste will be very expensive for the customer to buy, also advise them most towel rails will not heat the bathroom.
Too cheap surely, even for a direct straight swap.
Or do you mean thats what the op should charge and not yourself kirkgas?
don't you know why a 50 p has sides on it :?: :?:
so you can use a spanner to get it out of a scotsmans hand
one post says i'm too cheap and one says i'm scrooge.
£275 for a shift and a bit, no outlay, no tax, no problem, i'm not a robber
Depends whether or not the OP is a proper company, pays tax, has Public liabilty, a van to run???
If not then I won't be offering any advice on the pittance he is charging ;)
