The hot water tap on our bath/shower mixer has started leaking this evening. Not sure of the brand of the tap but the washer has an outside diameter of 16mm, with a 5mm diameter centre hole.
I thought it was just a case of getting a replacement from the nearest DIY place. It looked like the 3/8" washers were the right width/thickness but the centre holes were too small.
Is it just a case of going to a specialist plumbing shop or could it be that I need an unusual size washer and may need to find out who made the tap (the bath and sanitary ware is Twyford so it may be one of their mixers).
I didn't think getting a correct sized washer was going to be this difficult!!
Many thanks for any advice that can be offered (apologies if this is a bit of a trivial question).
Damian
Damian
