    Dismiss Notice
Bath tap washer won't fit over bath hole
Discussion in 'Plumbing and Central Heating' started by messimagician, 15 Aug 2020.
  1. messimagician
    messimagician
    26 Apr 2014
    54
    Thanks Received:
    Manchester
    Country:
    One of the bath taps broke so just had to buy a new set. After finally removing the old tap which was a struggle, I noticed the bath tap had some sort of clay type compound all over the thread and inside the square indent in the ceramic bath. I'm guessing the square indents were to stop taps spinning?
    Anyway the new taps washer don't quite cover the square so water will flow down the tap hole
    Any suggestions what I should use to either build up the square indent so I can use the washer or is there away without using the washer?
  2. Sponsored Links
  3. Madrab
    Madrab
    4 Oct 2012
    7,815
    Thanks Received:
    2,193
    East Renfrewshire
    Country:
    You would usually use what's called a split kick (square) or top hat washer. That and a little silicone to fill in any gaps if needed.
  4. polesapart
    polesapart
    27 May 2011
    1,266
    Thanks Received:
    317
    Country:
    Perhaps "Essex Yellow Fix-a-Tap Tap Fitting Kit for 3/4" Taps"
    or choose a tap with a wider body (+ top hat washer underneath)
    or gub it up with silicone/CT1/SticksLikeSh*t or similar.
    I'm guessing your's is cast iron bath vintage 1960s or earlier.
  5. footprints
    footprints
    21 Sep 2011
    4,426
    Thanks Received:
    943
    Country:
  6. messimagician
    messimagician
    26 Apr 2014
    54
    Thanks Received:
    Manchester
    Country:
    Yeah the house was built in 60s so the bath is probably from back then
    The taps base just covers the square holes. the washer that was provided with the tap is 45mm in dia and is a couple mill short so any water would just seep under the tap.
    The top hat washers that I looked up only seem to be used for securing the tap ?
    It has timber knocked up under the bath where the tap holes are so I don't think the tap will be loose once tightened with the brass nut
    The main issue is filling up the square and sealing the tap base
    I have used CT1 before and it's strong stuff.
    Would plumbers mate work? Just trying not to go down using extreme CT1 measures haha
  7. oldbuffer
    oldbuffer
    6 May 2010
    1,305
    Thanks Received:
    487
    London
    Country:
    1. Plumber's Mait won't work - it's non-setting.
    2. A bit of brass flat 5 - 6 mm thick drilled to accept tap then cut in square to fit hole. Another round washer of same under bath.
    3. If you want to be really posh, get it chrome plated - but it will cost you £50 to £100 in my experience.
    4. Alternatively:
    4a. Use aluminium and polish it with Brasso. Try and insulate it (tap?) where it touches the bath and taps, or you will get electrolytic action and it make corrode into place.
    4b. Use Delrin or similar plastic. Perhaps black for contrast. Again can be polished with Brasso.
  8. messimagician
    messimagician
    26 Apr 2014
    54
    Thanks Received:
    Manchester
    Country:
    I just went with plumbers mate, I rolled it up evenly and placed it around the square. I then tightened the tap up with the plumbers mate squeezing out. I trimmed it back and cleaned it all up so it looks nice. It's barely visible.
    The tap is rock solid and tight to the timber, it's not moving. I tested it with spraying the shower head around the tap and not a single leak underneath bath
    It will be only a temporary fix anyway until we get a new bathroom as everything is dated
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
