Bath-to-tile gap: sealing a wide gap
16 Mar 2005
I've recently tiled my bathroom and left a 1/2 inch gap between the tiles and the bath. This seems a bit wide to seal with a bead of silicon. The install notes that came with the bath recommend a 1/4 inch gap. And filling the bath with water will increase the gap even more.
What are the best options for sealing this gap? Wickes sell L-shaped plastic profiles. But do they stay stuck?
Mike
Cant the height of the bath be adjusted to reduce that gap?
if not then you can go down the road of the sealing strips but i'd rather use silicon. i'm sure somebody else has a better opinion on here though...
>Cant the height of the bath be adjusted to reduce that gap? <
Good idea. But I'll have to see whether I can reach the bath "legs" now it is all installed. Also, I'm not sure how play there is in the plumbing pipes.
Otherwise, it will have to be some sort of plastic strip.
Mike
Why the devil did you leave a 1/2" gap - even a 1/4" is too much. 2mm is the most you want to be leaving.
Completely forget the plastic strips - they are truely garbage, come unstuck and get grubby real quick.
If there is no panel on the bath you should be able to adjust the feet a bit,the plumbing should allow you to adjust such a small amount.
You can get a quadrant type beading made by homelux has an adhesive strip on one edge,its not ideal but when its fitted and siliconed in will cover the gap and looks quite neat.I fitted some around my dads bath about 5 years ago and it still looks good after a squirt of bath cleaner and a damp cloth.
The "L" shaped strips are really naff and a waste of money.
