Bath with shower run off taps
16 Jul 2009
Hull
is it ok to have a window in the showering area of a bath with a shower run off the taps. Would water getting on it be a problem. Its a frosted pvc window which doesn't open.
Any water landing on a timber window frame isn't the best......could you consider running a shower curtain across it? Prevents silhouettes, too :P
John :)
Ok, but you still need to prevent water lying on the sill, which will eventually get into the wall behind. The corners are the worst offending areas!
John :)
