is it ok to have a window in the showering area of a bath with a shower run off the taps. Would water getting on it be a problem. Its a frosted pvc window which doesn't open.
Ok, but you still need to prevent water lying on the sill, which will eventually get into the wall behind. The corners are the worst offending areas!
John
