Hello, I'm changing basin taps on a low pressure supply/system so will be joining 15mm copper with 15mm compression with isolation valve x 1/2" flexible pipe connector. Should I be concerned at the flexi pipe bore size, as the majority appear to be 10mm, although there do appear to be some that are 13mm bore. On a low pressure system, will there be much difference in the water flow? Thanks
