Bathroom ceiling build up with cold void above
It's a requirement. Obviously they weren't needed in the olden days, but time moves on, things improve.
Also lots of older houses have damp and rot issues, due to the way they were built.
If you're doing it then do it right. And don't tell others to botch it.
The ceiling joists go in a different direction to the rafters and are not connected at the WP. Is this a lean-to roof as suggested by 23vc?
Not my house pictured, but it's like the first floor back room here:
The ceiling joists don't make contact with the wall plate, just the roof rafters. It's been up long enough and isn't presenting issues, i'm not too concerned about the structure.
If you're starting from scratch, as it sounds, then there's absolutely no harm in doing the work in accordance with modern standards.
Basically build a modern home within an old shell.
