Bathroom Doors locked inside - unable to open
Try and take the pins out of the hinges.
Cut the hinges with an angle grinder
Cut through the latch with a junior hack saw blade.
Andy
Unscrew the handle.
Use a screwdriver to open the latch, or slide a bit of coat hanger into the frame and door and pull the latch back.
No worries its a basic internal door knobset.
Wont work on a front door :mrgreen: :mrgreen:
this happens usually when the locking knob on the inside is just at the point if flicking over to the lock position. when you close the door, the movement/vibration is enough to move it fully to the locked position
Alarm - If i manage to get the front door open with this trick, then i will be the most wanted :)
bhm1712 - yes, the locks i assume should be around 30 years old. I looked at some videos of how to change the knobs for privacy locks. In the videos, the privacy knobs had a screw in the front, but i am unable to find one in mine? If i want to chage this, then should i need to replace the whole door? This know is ok for our toilet, but, i should change the locks for the guest ones.
Any suggestions of how i can do this?
