bathroom down lights
LED's run cool. 12 volt is DC like a battery and works from transformers. 240 volt is AC mains power. Therefore you'll not kill yourself when water or damp gets into your 12v circuit, but with mains you could be dicing with the grim reaper. There are regs on bathroom zones and only 12 volt DC can be fitted in certain areas.
LED's run cool.
LEDs do get warm, some larger ones get hot.
They are using liquid cooling in some aimed at the domestic market.
Parts of an LED lamp can be hot.
Hence "It depends. What sort? How powerful? Touch where?"
But "why does it matter?" seemed reasonable. Who touches lamps? In a bathroom? Why? Where do they touch them?
It doesn't have to be DC.
But basically it never occurred to me that the OP did not know the difference between 240 and 12, or that a voltage 1/20th of another might be safer.
We have 240 volt LED downlights, the ones equivalent to GU10 bulbs. They're never on for any serious length of time but generally speaking there's no heat from them. They simply plug into the existing holder with no fancy drivers etc. We got them from ebay about a year ago and have had no problems.
