Bathroom downlights stopped working
21 Feb 2012
Tyne and Wear
My bathroom downlights have suddenly stopped working.
I have five downlights and one is an extractor/light.
They have all stopped working, so far I've tried changing the light switch, switching out all the bulbs (which are all GU10 bulbs)
Does anyone have any ideas of what could be the issue or what I can do to test.
You likely have a break in the wiring.
Check continuity of the conductors to determine where the break is.
Loosen the switch off and measure across common (L1) and the earth.
Not to confuse the OP. Some switches are marked COM, L1 and L2. Some are marked L1, L2, L3.
You need to measure between the earth and the line feed in to the switch. This is usually (but not always) the red or brown wire.
