I've removed the pendant light in the bathroom and fitted three Zone 1 spotlights which are low voltage with a transformer. I understand this is 'notifiable'. Who do i notify? Do i get an electrician to check my work and issue a certificate which i supply to Council or do the Council check my work? How much does this cost?
Before i do this, I want to remove the electric shaver socket and conceal it in the wall. Does the electician / Council person need to check this before i plaster the hole?Is it appropraite to simply run the cables into a connector block, thoroughly tape up and seal in plastic bag before packing out and plastering?
If i wanted to install a mirror with built in lighting instead, could I extend the electric shaver socket wiring into the mirror electrics?
Many thanks
Many thanks
