Bathroom fan controlled by dimmer switch
20 Aug 2009
Dorset
I came across a bathroom fan that comes on with the lights via a dimmer switch.
My gut reaction was to change it all, with a 2 gang switch consisting of one dimmer and one on/off switch.
And then I thought, do I actually need to?
What do you all think?
Is the fan directly powered via the dimmer, or is it just the switched input so that the fan runs on a timer?
The fan goes off as soon as the dimmer is turned off - I think it was intended to be on a timer, I'm told it is a humidity fan, but apparently the electrician couldn't get it to work correctly...
