H
holmslaw
It is, isn't it.the SP neutral switch in the OP's original proposal is surely an issue
I'm not trying to mislead anybody.BAS you are misleading people again,
All the quotes above were genuine - I did not falsify any of them.You then jumped in with both feet and attributed comments from other people to me.
I've already admitted it.And you're not man enough to admit your mistake.
in response torearrange these words "don't I what I'm talking about know"
What had you decided merited that?Isolate the circuits using a relay powered by the light switch?
Not sure how it would trip the RCD, however I would think having a socket circuit running into a light switch would be a bad idea unless the light switch has a warning label on it.
Maybe you should have only quoted that bit of his post then, not the other two parts.My comment was based on the notion of introducing a relay which demonstrated the ops lack of knowledge/experience.
I answer all your queries.
And what does the 3-pole isolator isolate that the FCU does not?try this View media item 43181
Are you asserting that I never answer your questions?Why don't you ever answer any of mine?
My comment was based on the notion of introducing a relay which demonstrated the ops lack of knowledge/experience. Have you noticed how polite I am I answer all your queries.
Stop misleading people and have you any idea how ridiculous you look, but carry on, I'm sure you're giving a lot of people a real larf.![]()
