Bathroom floor build-up & Underfloor Heating: 15mm ply + 10mm insulated board — overkill or smart?
21 Sep 2025
Hi everyone,
I’m planning of redoing my bathroom floor and I’d appreciate some input from the experts here. The main joists are spaced 43 cm apart. Right now, there are a few bridging pieces (I guess you could call them noggins) running between the joists about every 2 meters, at lest this is what I managed to see.
I have 2.5cm to play with between the main joints and tiles. My plan is to use 15 mm plywood and then put a 10 mm insulated cement board on top to have the best thermal efficiency. To maximise structural rigidity, because of the fact I am using 15mm ply-wood compared to more commonly used 18 or 22 mm, I am thinking of adding few extra noggins in between the joints, say every 80-90 cm, to get more support for the plywood and avoid deflection.
Then I’ll lay the electric underfloor heating mat, apply tile adhesive, and install 60x60 cm tiles.
My questiona for you are:
1) does this setup sound good to you? Buy adding some extra noggins will I be able to use 15mm PlyWood instead of a thicker one?
2) Is it worth doing some extra work in order to usev10 mm insulated board instead of a 6 mm? Is the extra thermal benefit of the 10mm really worth the extra work of adding more noggins?
Thanks a lot for any advice!
I know this doesn’t answer your questions, but… why are you going to put down cold-under-foot tiles and then heat them up with expensive electricity, rather than just putting down a naturally warm-feeling floor?
