Hi folks,
First off in reply to gaz, So because I am putting a 25mm WBP ply board straight onto the floor joists, I need to use a special type of adhesive? Im guessing that type of adhesive will be a tad more expensive which leads me to think on my next question.....
Do you think Id be better off putting a 9mm ply floor down first and then putting down 15mm so as to avoid this problem or is this not worth offsetting the cost of the C1S2 adhesive.
In either case thanks for your insight..
Second in reply to Richard, the tiles that would be going on to this area are 10x10 standard ceramic... nothing that unusual or that especially heavy.
Behind the blue plastic is a cavity and then I think its straight onto the "inside" of the roof of the house.
This is why I am a little reluctant to puncture the blue plastic as I presume it was put there as a final line of defence against any water ingress.
Thing is though there are screws already in place which were holding the pb in place which would be difficult to exactly match up on the new tile backer. Maybe Im worrying about nothing on that.
As for getting in behind the wall with the cable coming out, on the other side of that is a cavity and then another PB wall which is the inside wall of an airing cupboard.
There does seem to be some rigid material in behind the blue plastic that isnt just fibreglass insulation but it seems really thin and almost placed there but without opening up the blue plastic I cant really tell exactly what it is.
One option I am thinking of is to open up the blue plastic and put some mini noggins in between the tile backer and the roof boards. Theyd only be about 6 inches long but would provide some rigidity against the board being pushed up and in towards the roof on its right hand side.
thanks,
Paula.
thanks,
Paula.
