Bathroom heater flex connection advice.
6 Sep 2004
I have allowed access to a neighbour’s home whilst he is away to both a carpenter, in order that a new built-in fridge can be installed, as well as an electrician to fit a replacement bathroom heater. It is in regard to the latter that I have a question.
It is a Dimplex FX20V with a pullcord and its flex is connected to a flush cord outlet like one of these. I have followed the circuit back to the consumer unit to find that it is connected to a 16A MCB (RCD covered) which I think seems to be correct. But should the flex from the unit not be connected an FCU flex outlet? I thought this was mandatory. But perhaps you cannot fit an FCU in a bathroom? Any comments would be appreciated.
Put the DP Switched FCU with neon outside the bathroom door, label it BATHROOM HEATER, and insert a 13amp fuse for a 3kw Heater, or a 5amp for a 1kw heater etc. problem solved. :lol: :lol: :lol:
No, not necessarilly.
No, it is protected by a 16A MCB plus the RCD.
As long as the cable is capable of handling more than 16A then all is in order.
You can if more than 600mm vertically from the edge of the bath or shower AND it is suitable for the environment of the room.
No point if not necessary.
