bathroom pull cord light switch
29 Aug 2007
Lancashire
Hi everyone!
I seem to have yet another problem in my house-are they never ending?? :(
I have a pull cord light switch in my bathroom. The light switch works both the light and the extractor fan. There is an isolation switch for the fan but that is currently switched on so the fan should come on when the light comes on.
The problem: When the light cord is pulled-it clicks-the light quickly flashes on then straight off or does nothing and the extractor fan does not work at all.
Do I need a new pull cord switch and if I do is it a particular type I need for this set-up?
Thank you in advance for your help,
Annette
it may be a loose connection or a worn-out switch.
they are not expensive so just buy a new one (MK or Crabtree, not one of the cheap ones). You want an ordinary pull-cord light switch, rated at 6Amps. should cost less than £5
have a careful look at your old one so you can buy one that seems the same. If it is old, see if you can buy a round pattress as used with some ceiling lamp battenholder fittings in case you need it to make a neat job (will only cost you 30p or something so no harm done if not required)
