- Joined
- 11 Sep 2007
- Messages
- 936
- Reaction score
- 11
- Country
I think the the pull switch in my bathroom is faulty - this evening I turned on the bathroom lights as usual but after a few seconds they went off. The pull switch clicks as it should, but no power.
Fuses in fuse box all checked and okay.
The bathroom lights are 12VDC spots - in my attic is a 240VAC to 12VDC transformer (I now forget the make and model - it is white, maybe DEF-105 or something likel that?). Checking with my multimeter there is no 12VDC output from this and also no 240VAC input. There is some very messy wiring in my attic (not done by me!) and from what I can tell the pull switch is switching on/off the 240VAC supply to the transformer (I had initially assumed that it would be switching the 12VDC output).
So, first thing to do I guess is to check if it is the switch at fault - I can disconnect it tomorrow and test with my multimeter with the continuity test across the relevant terminals.
However, if it is faulty I'll need to replace the switch - these are easy enough to obtain but just from looking online I see that they are available in different amperages such as 5A, 6A, 10A, etc - what am I likely to need? There are five 12VDC spots in the bathroom.
