I have a Car Battery Booster that I'm trying to charge up, but it's struggling to get up to voltage. Actually I'm not sure whether this should be 12vdc or 14vdc - as per vehicle electrics - but I'll leave that bit for the moment.
I tried to test the transformer with my multi-tester, but couldn't get a proper reading.
Ignoring the actual application at the moment, what reading should I be getting when testing the output from a (any) AC to DC transformer ? The one that came with it - that I'm testing - is rated at 15v 500Ma.
When I test it at the barrel (20vdc on tester - centre pin +), I get a 1.
I initially assumed that it was faulty & was looking for a replacement. The Booster says it needs a 12vdc input.
I tested another transformer from my home phone, & that likewise gives me a similar reading. This is fully functioning, as it's used all the time on my phone.
So - now I don't think there is a problem with the transformers. I think the problem is with the user not understanding electronics. I assumed it would read 12vdc (or 14vdc).
2/ If I do get another transformer, should I:
a) get a similar 15v 500Ma ?
b) get a 12v 500Ma ?
c) would a different Ma size help the charge in this instance &/or help the lifespan of a transformer ?
many thanks for reading this.
